Balsa VS foam core
Corley
Re: Balsa VS foam core
Post by Corley » Sun Dec 22, 2013 10:11 am
I'd question the blanket statement that balsa isn't used on performance race boats. They tend to use a mix of materials to best need the core requirements of particular areas. For example the maxi trimaran Sodebo uses balsa in some areas.
http://www.atlcomposites.com.au/files2/ ... pdf_ud.pdf
btw in durakore the balsa is oriented with the endgrain between the outside veneers not long grain.
http://www.atlcomposites.com.au/files2/ ... re_new.pdf
Post by Whimsical » Fri Dec 27, 2013 12:07 am
All the balsa cores that I have seen are end grain. Has to be that way to get the properties correct.
