Finally Does It
Re: Finally Does It
Post by 44c » Tue Mar 07, 2017 8:34 am
Good thinking. You can also keep any mixed but unused paint overnight in a fridge. We have kept paint useable for weeks in a freezer.
Not the fridge you keep food in though!
Re: Finally Does It
Post by Finally » Tue Mar 07, 2017 11:15 am
The trick is - not to get it too cold otherwise condensation becomes an issue.
dazza
Re: Finally Does It
Post by dazza » Wed Mar 08, 2017 6:55 pm
Well done David , it's a credit to you to keep going through the summer in Cairns and doing a top job too.
makes me feel like guilty moaning about the heat in the shed.
What size torture boards did you use, were they bought off the shelf or did you make them ?
Cheers Dazza
Re: Finally Does It
Post by Finally » Wed Mar 08, 2017 7:53 pm
Dazza
The boards, by and large, are not mine but they are a mixture of bought and homemade ranging from 1 metre down to (believe it or not) thumbnail size to get into those hard to get to places.. Some are stiff, some are flexible (Dura-Block, pieces of 10mm foam with velcro stuck to them), some are thin <10mm, some are quite thick (3 pieces of high density foam glued together so about 75mm).
Acutally, I'll lay them out on a table over the weekend and take a photo. You'll be amazed as to how many are used.
Set the thermometer on the duckboard today. It was almost down tools weather. 30C in the shelter where the boat is at 8.00am with 85% humidity. Got to a tad over 40C in the shelter with the humidity still around 65%. Lost count how many bottles of water i drank.
Re: Finally Does It
Post by 44c » Thu Mar 09, 2017 12:42 pm
Finally wrote:The trick is - not to get it too cold otherwise condensation becomes an issue.
Yeah, keep the lid on as much as possible, keeps the water out.
dazza
Re: Finally Does It
Post by dazza » Mon Mar 13, 2017 6:55 pm
Your boom looks pretty cool are there plans for it or did you just wing it ?
Dazza
Re: Finally Does It
Post by Finally » Mon Mar 13, 2017 8:41 pm
dazza wrote:Your boom looks pretty cool are there plans for it or did you just wing it ?
Bought the plans from Mick from ROAM who also built one. The plans give you a step by step process to build one and were easy to follow. The booms are not engineered but are being used on 5 cats - the biggest being ROAM's. I understand It was originally built for Big Wave Rider (46' Chamberlain) who really gave it a testing during his around Australia record (particulalrly the section from WA to southern Tassie). No failures on any of them so far. The 2 boats mentioned above are bigger than mine so I thought that was a good enough testing ground for me.
Re: Finally Does It
Post by 44c » Tue Mar 14, 2017 7:27 am
With end of boom sheeting, and no vang, the loads are pretty minimal anyway. Just outhaul loads really.
Re: Finally Does It
Post by 44c » Sat Mar 25, 2017 7:17 am
Hey Dave, hope Debbie doesn't do Cairns, and stays well away!
Re: Finally Does It
Post by Finally » Sat Mar 25, 2017 7:28 am
Bit of a coin toss whether or not to take the tarp off the shelter. As of last night the models had it crossing as a Cat 3 or 4 anywhere from Mission Beach to Bowen. If Mission Beach we can still expect gusts up to 65 knots in which case I will take the tarp off. If Bowen, then it's too far away to worry us.
Waiting for some updates this morning before making the final decision.
Might be a busy day.....
