Post
by mahnamahna » Fri Jun 15, 2012 8:29 am
Hi John, not sure you would want to put the film on both sides, mostly because it may result in loss of visibility through the windows. Most cats require visibility through the windows from the helm. On Nine lives he had dark acrylic on his aft cabin window as well as the forward cabin windows and all he could see from the helm was his image in the black mirror. You cant see through 2 sets of dark tint, I imagine the silver tint would be the same.
The other information I did not relay is that the good film is about $100 a square meter installed if they come to me, about $90 a sq meter if I take the windows to them, I have about 6 square meters of windows on my boat. I have a lot of window area in my boat, see pics above, including into my bedrooms.
And to put that into perspective, I have had a quote for the actual windows of about $2000 including 4 of them going into the oven ($100 per window that requires heat molding) for 8mm clear acrylic. Polycarbonate is about 20% more and dark (black colored plastic in either poly or acrylic) is about 20% more again. So my windows are going to be around the $2500 mark regardless of which kind of tint I go for or 20% more if I opt for polycarb.
So the film is about 25% of the cost of the windows.
But the window tint film is about the same cost as plastic pre tinted.
Acrylic is harder wearing than polycarbonate, in that acrylic resists scratching better but polycarb is stronger (it is technically softer than but stronger than acrylic). The window tint film is more scratch resistant than either polycarbonate or acrylic and is made from Polyethylene terephthalate (PET). Not that that means much to me, but it might to the more chemistry minded here. Its more scratch resistant is all I need to know. That is what leads me to lean toward fitting it to the outside of the windows even knowing it wont last as long. I figure its the outside that are going to scratch. And scratches and crazing are the enemy of plastic windows.
Perhaps one of the more longer term cruisers could answer this, how long did your plastic windows last before they start to craze? Did that crazing make you wish there was a way to reduce or stop it, at the cost of say $500 every 5 years would that have convinced you? Were they badly enough crazed that they needed to be replaced (whether you did or not?). This is the kind of information that might help some of us decide which is the best way to go.
Allan (44C) in particular, as he has experience with the film option.
