steering
steering
Post by northerncat » Tue Aug 22, 2006 9:02 pm
what method are people out there loing at for hooking up there steering to there rudders, im trying to look into this area and i quite like the idea of using the solid rod that they use for small outboard powered runabouts
Trevor
steering
Post by Trevor » Wed Aug 23, 2006 10:20 pm
I am using the morse cable setup as Peter did on Take it Easy. This seems a simple method but I still have to connect to the console. I hope to do this soon.
Trevor
steering
Post by Smooth Cruiser » Wed Aug 23, 2006 11:11 pm
Tillers
steering
Post by puremajek » Thu Aug 24, 2006 7:21 pm
900mm steering wheel, to cog, to spectra rope through 4 sheaves to rear 'tiller connection bar' and stowed emergency hand tiller as back-up.
steering
Post by 44c » Fri Aug 25, 2006 4:11 am
Going Hydrive hydraulic. Easy install, as many steering stations as i want (or can afford, at the moment I am actually considering 3) you can get decent hydraulic autopilots for reasonable money, it all fits for me.
steering
Post by madaz » Wed Nov 19, 2008 7:13 am
Is there an easy answer to getting a 1" straight shaft wheel onto the 3/4 tapered teleflex shaft? i have got a 1" bush but then the plastic bezel cover doesnt fit over.
Everything I thouch at the moment is turning to SH#T.
steering
Post by puremajek » Wed Nov 19, 2008 7:50 am
Madaz
I feel your agro. We went through exactly the same. Our simple resolve, traded all the bits back in for a refund (except the wheel and shaft) – got a welder and welded the shaft to the wheel. Done
Now we just slide the wheel/shaft assembly into the bearings, lock with a key and two grub screws. No nuts, bushes, bits of plastic, not even a washer. Best of all, its straight and works a treat.
steering
Post by madaz » Wed Nov 19, 2008 7:54 am
i'm getting to the point where walking down to the shed with a box of matches is sounding very appealing.... :twisted:
steering
Post by Jim » Wed Nov 19, 2008 10:03 am
There is an adaptor in the BLA book for the straight/taper bits. I have one but it difficult to get the wheel tight.
steering
Post by puremajek » Wed Nov 19, 2008 10:11 am
Palm the little one of to the in-laws, grab the wife, couple bottles of good Tassie red and go and stay a few nights in the Hobart Casino. The 'Bird Cage' has a great pianist at the moment by the name of Greg Andrew. Very easy listening :wink:
