ply wood from boatcraft or plywood + panal
Some quick ideas, fixes, resins and joinery hints and building tips
markg
Post by markg » Thu Jun 13, 2019 6:03 pm
Hi guys
Im about to build a waller 1200 and the designer recommends gaboon ply
boatcraft quoted for a 9mm sheet $133.19 + gst
plywood + panel quoted for a 9mm sheet $79.57 + gst with the Lloyd's Certificate demonstrating it being certified to the requirements of the British Standard BS1088 for marine plywood
my head is spinning
Has anyone delt with plywood + panel before ???? going to go and have a look , but I'm onshore what I'm looking for in a good ply
thanks mark
Re: ply wood from boatcraft or plywood + panal
Post by mikeb » Tue Jun 18, 2019 9:07 am
Hi Mark
I claim no expertise here but I do know that the Llodys certifciation isn't as stringent as the Australian.
I'd check the weight as the cheaper panel may only have gaboon on the outside and a heavier core. I'd check the number of layers too. It's a big price difference, might be work buying the cheaper one to cut it up and see if there's many voids etc.
Good luck, Mike.
Bingo
Post by Bingo » Tue Jun 18, 2019 10:56 pm
U know wot the bs stands for in bs 1088, poor quality control, 2272 is the Aussie standard. Having said that I’m using the dragon brand made in Indonesia to do my extensions. It is lightweight and has the type a phenolic bond. Bunnings mob have been selling it here in Darwin for bout 12 months and it’s way better quality than the Malaysian brand they were selling. Boatcraft call it pink marine ply and they give it a pretty good rap. Good way to test any marine ply ( bond) is to drop a bit in the drink for a few days and see wot happens. Cheers. Steve
Bingo
Post by Bingo » Fri Jun 21, 2019 10:03 am
Just to clarify wot was said in an earlier post the bs 1088 is a British standard enforceable in the uk, (quality control). Most of the marine ply sold in Australia comes from Asian countries some carrying the 1088 logo which may not be suitable for boat building. Do your homework research thoroughly. The type A phenolic waterproof bond is to me the most important consideration, if the boat is built properly incapsulated in epoxy u won’t have any problems. Cheers Steve
Beav222
Post by Beav222 » Tue Aug 06, 2019 1:23 am
I’m in the US so take this with a grain of salt.
As I understand it, here in the US anything sold that has the BS 1088 must meet the standard. There are products that come from China and other places that have the BS stamp and may have Okoume or Meranti skin which are both a Species of mahogany but have inferior middle ply’s. Here is a link to some good information https://www.marine-plywood.us/mahogany_okoume.htm
Peter Snell says any ply you use on your boat must pass the 24 hour boil test. I did this with the ply I bought from Windsor plywood here which is a Canadian based company. I gave it the test and it passed with no I’ll effects that I could see. Time will tell.
Dean :lol: & Debra :mrgreen:
— Mark Twain American Writer.
Beav222
Post by Beav222 » Tue Aug 06, 2019 1:56 am
Hi guys
my head is spinning
thanks mark
Ahoy Mark.
Every product should have paperwork associated with it in the form of certification or specs. We should always ask for documentation when building boats as we are the ones that stand behind the build. The designer or architect should be the one that certifies the design specs. As with any other products we should ask for certification so we can defend our product too. I’m not a Lawyer but I feel if I was sailing and had some sort of failure in a building material I would need the proof that I built to the highest specs.
Cheers, Dean
Darren
Post by Darren » Mon Oct 14, 2019 2:55 pm
I saw that Bunnings were flogging "Marine Ply" - no markings of any kind in terms of what they mean. Just AA faces, hardwood, marine quality bond. Very non specific
