Do You Tweak?
Shut down the iron sail, learn how to trim your sails and be first to the best anchorages.
Re: Do You Tweak?
Post by Finally » Tue Feb 25, 2014 1:58 pm
It looks like the white line is the original sheet which leads back to the jib sheet track (though you can't see this). I would then presume you would take the load off the block first (let out the blue tweaker line), take in on the jib sheet then remove / relocate the tweaker block which which won't have any load on at all.
Re: Do You Tweak?
Post by 44c » Sat Mar 22, 2014 12:03 pm
Corley wrote:Here is the tweaker on Charles Meredith's "Peccadillo" a Chris White Atlantic 46' design cat. It's a block with one cheek that can be unclipped to drop over the sheet and lashed to one of the docking cleats. It works very well and gives much better control over sail shape than just the track.
I like my arrangement better! It's cheaper, simpler, and IMO gives more control of the clew. I can use the sheet against the tweaker to put the clew pretty much wherever I want it.
Re: Do You Tweak?
Post by groper » Mon Mar 24, 2014 7:56 am
44c, you have a PM...
